I am trying to use a F
lexmotion PCI-7344 with LabView for use as a Parabolic Antenna controller. The Problem is feedback from each axis (AZ & EL). Each axis uses 2 Synchro's (1:1 & 36:1 for Course & Fine 90V / 60Hz) for feedback. I have no choice in using synchro's as feedback.In our normal system, we use 16 or 12 bit S/D converters. This is then looked at via very custom software and the target position is derived from it. The corresponding position is then sent through a D/A converter and output to a servo amp. I thought I could feed the Syncho outputs to a S/D converter, then to a D/A converter, then into the analog inputs of the PCI-7344. The problem I run into is that the D/A's (12 bit) see 1000|0000|0000 as 0 volts output. The S/D converters, when the
antenna is at physical 0 degree's, output 0000|0000|0000. If I'm correct, I need 0 volts input to the PCI-7344 to indicate I'm at 0 degree's. I've tried playing with the bits between the S/D and the D/A with no success. This therefore led to my last question I posted. Can I feed the output of the S/D's to the digital lines of the PCI-7344 and use it as feedback? I also am trying to figure out a way of letting the controller know what sector I'm in - CW or CCW. I have a cablewrap voltage as a possible feedback for this. +/-15Vdc depending what sector the antennas in. The antenna must be able to physically track in a possible pattern starting at -90 degrees, through zero degree area, up to 90 degrees or vice/versa. Right now I would be happy with the controller to be able to position the antenna to a count which corresponds to actual position. If anyone has any idea's, they would be greatly appreciated!!!! I hope this awnsers some of your questions Yellowjacket. If you see a solut
ion that I didn't mention feel free to let me know.
(5,084 Views)
lexmotion PCI-7344 with LabView for use as a Parabolic Antenna controller. The Problem is feedback from each axis (AZ & EL). Each axis uses 2 Synchro's (1:1 & 36:1 for Course & Fine 90V / 60Hz) for feedback. I have no choice in using synchro's as feedback.Hi motionman,
Have you considered wiring the S/D data directly to the 32 digital lines that are available on the 7344. There isn't a way for the board itself to use that data as feedback... but you can write your program to interpret the 12 bit data that you are getting. The performance will not be nearly as repsonsive, but you can basically write your program to decode the data in software.
As for your question about CW or CCW, you may have trouble with the 15V signal since the analog inputs for 7344 are rated for +-10V. But if you want to wire the signal to a relay then you can use the digital i/o lines to read this.
Ken
(5,084 Views)
