PCI-7344 - Initialize Error
When I initialize the PCI-7344 with MAX (standard/default settings) i get the following error-Code:
"-70013 (packetLengthError) occured in Configure High Speed Capture on Axis 0x01 (command packet length is incorrect)."
I´am using Win NT. The PCI7344 is brandnew and there is no caple plugged in the
7344 controller !
Is the PCI-7344 defect - or is it a Software-Problem ?
(5,643 Views)
Hi Renz,
Make sure you have Flexmotion 5.0.1 installed on your computer. Go ahead and try to "Reset Device" on the status Tab in MAX. Then try to initialize. If you still get an error, I would try this board in another computer to try to reproduce the behavior.
If it's the same on a different computer, the board could be bad.
(5,643 Views)
