Is servo controller will Drive Servo Motor DIrectly?
Is One NI PCI 7342 able to Control Both Stepper and Servo Simaltanously? Also If the Motor is not Loading am i required any Drive to Drive motor? Will Controller able to Drive Motors??
Pls someone answer me because i am very new to Motion Control Section
Joe
Using Ver. 8.0
(3,113 Views)
The PCI-7342 can control two axes simultaneously. You can configure each axis either as servo or stepper axis and yes, you can mix these axes.
The PCI-7342 is a controller board that can't drive power. Thus you need an external drive to connect your motors to.
Jochen Klier
National Instruments Germany
(3,107 Views)
