Motion Control and Motor Drives
Is there and easy way for Position control using analog input?
Hi Everyone,
I would like to set one of the axis with stepper motor using analog feedback to keep the set position which is coming from the analog input.
In other words I would like the stepper to move when the analog input changes. I need it as a "background service" so the rest of the motion could be easily controlled from the NI-Motion Assistant.
Is there any easy way to do this? Even complicated is ok but the control should be done by the NI Motion card not the PC processor.
Andras
(3,372 Views)
Hello Andras,
please use the link below to get the motion example.
http://zone.ni.com/devzone/cda/epd/p/id/353
Kind regards,
Elmar
(3,364 Views)
