LabVIEW VI for an Automation Direct STP-DRV-6575 that doesn't have a serial port connection?
Does anyone know how to control a stepper motor using LabVIEW and an Automation Direct STP-DRV-6575 that doesn't have a serial port connection?
(6,023 Views)
This is a simple step and direction input drive.  You will need a motion controller to control it.
(6,014 Views)
Can I create a virtual motion controller with LabVIEW?
(6,009 Views)
What do you mean with a Virtual Motion Controller? You will need an actual card to send the step and direction signals to the drive itself.
In what concerns a virtual controller, you can create a virtual motion controller in the Measurement and Automation Explorer (MAX) which will allow you to develop your code without the card, but it won't allow you to actually control your drive. More information regarding virtual controllers can be found here:
http://digital.ni.com/public.nsf/allkb/B8C8B4866CD33E7B86256FA50003B933
Cordially;
Simon P.
(6,001 Views)
