Lookout Loader Object load/unload alarms
I have a main application that can load 2 (may be 3) other secondary applications when needed. What I want is set push buttons on the main application for loading each secondary. I would like to have the unload push button on each secondary application, not on the main application. How do all this? How avoid the alarms?
(2,934 Views)
Hi 23r23,
Follow the instructions on the following example to get it working. Once it is working, create a pushbutton on the panel of Loaded_Process_1 that connects to the unload datamember of the Loader1 object on the Loader process. You can then delete the Unload_PB_1 object in the Loader process. This will create an example of Loading a process by a pushbutton and then unloading a process from a pushbutton in the loaded process.
Example: Loading/Unloading Lookout Processes Programmatically
I tried this and did not get any alarms.
Chad Evans
(2,934 Views)
