Mesauring position and speed in a 3 phase BLDC motor?
Hi!
I was wondering if you could help me with a problem. What I want to do is control and measure a 3 phase BLDC motors position and speed prefferably using a PID controller (or two!).
The position part isn't too hard (I think I got it!), but having a PID controller measuring the time from the trigger pulse to the desired position within a desired time is harder. The speed-PID controller should automatically adjust parameters so the next motor rotation will get to the exact position within the desired time.
Can anyone help me with this problem?
(3,958 Views)
Could you please provide some information about the hard- and software that you are using to control the motor?
Jochen
(3,952 Views)
