vision and motion of a arrow
Hi i have a problem of following a arrow through a camera and follow it motion
i can track the arrow no problem ,but now i have to follow it path  ,and to track the path about 30 or 100 meters
i must have the arrow always in focus of the camera i have no idea how to begin  to give the feed back to the motor to move .
I have enough distance to track it whole path in terms of reach.
but now to have to covered it all time ´s in focus to full screen and keep it there is some problem where i have no idea where to begin.
the arrow moves with about speed of sound   340 m/s
Because it in the field  we have a 6210
Any one brilliant idea how to solve this  ( for the next olympics)
Message 1 of 14
(5,320 Views)
Hi cees10,
I'm assuming the camera is fixed to a platform that is connected to the motors. The first thing to determine is how much does your camera's field of view change as your motor moves. In other word, given one rotation of your motor, how much do stationary objects in the images from your camera shift? Next, you can measure how much the arrow has moved one frame to the next. With this information, you can move your motor based how far the arrow moves in your camera's field of view.
For example, lets say your arrow is stationary and you move your motor on full rotation. When the motor is done with its move, you notice that images from your camera shows that the arrow has moved over by 500 pixels. Now lets say we have the arrow centred in the images from the camera. The arrow moves and you measure that it has moved over by 50 pixel. This means that you should rotate your motor by 1/10th of a full revolution to keep the arrow centred in the camera's view.
Message 2 of 14
(5,300 Views)
Well thanks for the respons Olivia
Field of view is 45 degrees       assume we put the camera   at the center of the 30 meters  .
The problem is that  the time is very fast    340 meter a second .
As i see it to move the shift of camera so fast  it has determine let say  50 pixel's  and on wich side the move motor all in a flash  with in 0.1 second
speed =   340 meters a second             distance is  30 meters
so i think a motor is not fast enough  0,1 second evrything is over en done
Let say the arrow is 0,5 meter       camera window is 0.7 meter so it needs  30/ 0.7 = 42.85      positions    in les then 0.1 second
Message 3 of 14
(5,295 Views)
Hi cees10,
If you think your motor is not fast enough, that is a limitation in your hardware and there isn't much you can do in the software to optimize that.  Also, keep in mind that every motor will need to have some time to accelerate and decelerate and you need to take that into account when building your application.
Do you know that the arrow will move at 340m/s every time you run your application? If so, you can try programming an open-loop application where you specify a speed for the motor that would be the equivalent of 340m/s for the camera. For example, if one revolution of the motor moves the camera 1 meter, then you want the speed of the motor to be 340 revolutions per second to have the camera keep up with the arrow. Keep in mind that this would an open loop option. This means that any disturbance to your system that may cause the speed of anything to change, will affect how well you track that arrow.
Message 4 of 14
(5,284 Views)
No that is something we want to investigate (aerodynamics of a arrow,and its behavior)
Well that why we need to track it movement ,  it can be slower or faster (depends on lot of things i guess
yeah
maybe something with mirrors?  to track the arrow?
just a tought!
still have no clue how to solve this
~ Olivia
Message 5 of 14
(5,281 Views)
Hi cees,
There's essentially two ways to control any sytem: open-loop or closed-loop. In your case, an open-loop option would be one that I had discribed in my last post. For an open-loop design to work, it requires the system to act in a very predictable way each time because no feedback is being supplied by the system. However, as you've pointed out, the speed of your arrow is not going to be the same each time nor will it be very predictable. Therefore this is not a viable solution for you.
The closed-loop option for you would be using two consecutive frames of the arrow images to determine how far it has moved and then moving the motor based on this. However, based on the speed of the arrow, you've said that your motors are not capable of reacting in 0.1s to the movement of the arrow. Therefore, to make it possible for you to implement a closed-loop solution, you will to either find a motor that can react (i.e. ramp up to a speed of 340m/s) very quickly or you need to slow down the speed of the arrow (which I think would defeat the purpose of your experiment).
Mirrors will not help you unless it will allow your motor to react more quickly to the movement of the arrow or slows the speed of the arrow.
Some other things to consider:
  • Does the camera have to move? i.e. Can you move the camera back so its field of view covers the entire arrow path?
  • Does the arrow always have to be centered in the images? i.e. Can you move the camera back such that the motor can move a little slower but still keeps the arrow in the camera's view?
Essentially, you're limited by the hardware and the parameters of your experiment. If it is not possible to change the hardware, setup or the speed of your arrow, it may not be possible for your camera to track the arrow.
Message 6 of 14
(5,261 Views)
  • NO
  •  i.e. Can you move the camera back so its field of view covers the entire arrow path?
 yes
  • NO
  •  i.e. Can you move the camera back such that the motor can move a little slower but still keeps the arrow in the camera's view?
Well i still have to decide how to solve this  , so its still open on evrything
MY next tought is a piston that moves    By air or oil  or     by   electric that pulls on a string that moves a half of a circle    that cab be done fast i think
The  question also here is how to give a pulse   from   certain amount of pixels  and would it react  fast enough
Message 7 of 14
(5,256 Views)
Something else you might want to consider is the capability of your camera. The average camera can acquire at 30 frames per second, which means if you are using the images as feedback, you'll only have 3 frames in the 0.1s to indicate where the arrow is. If you're using a high speed camera or one that can acquire at a faster rate, this could help you out as well.
Message 8 of 14
(5,240 Views)
We have a camera for this    at   30.000 frames a second  at   full HD
Message 9 of 14
(5,238 Views)
If you perform image processing, you might want to avoid using full HD. The larger the images you are processing, the longer it will take. Therefore, this will add to any delay in the reaction of your system to the movement of the arrow. You may want to think about acquiring images from your camera at a lower resolution or bit-depth. However, if having detailed images is important to your application, you will need to find a balance between getting the amount of time it takes to process the images and the reaction time you want.
Message 10 of 14
(5,215 Views)
