Modulus Position
I have a rotary axis with 400 steps/revolution and I want to use the modulus position operation mode to control it.
Using MAX 3.1.1.3003 I set the axis position to 3 steps, the target position to 392 steps and operation mode to Modulus Position. The resulting trajectory that was a displacement of 389 steps, almost a complete revolution and not a displacement of 11 steps (the shortest path) as I expected.
Is this what supposed to happen?
Thanks.
(3,194 Views)
Before the Modulus Position mode works correctly you will have to load the Position Modulus parameter. This value doesn't correspond automatically to the steps/rev value parameter that you have set in MAX.
LabVIEW:         Load Position Modulus.flx
Other IDEs:     flex_load_pos_modulus()
Using this function:
This function sets the modulus used when the axis is operating in Modulus Position mode. It has no effect when the axis is operating in other modes. When a target position is loaded, it is interpreted within the boundaries of a modulus range.
After that the motor should move as you expect it to do.
Jochen Klier
National Instruments Germany
Message Edited by Jochen on 05-18-2006 04:35 PM
(3,190 Views)
