Multiple Cursor Manipulation and Image Processing
Hi Guys,
Firstly, can i check how do i manipulate 2 and above cursors in an image itself?
Next, i am using imaq count objects 2 for image processing currently, however i realized that the bounding rectangle which is formed upon satidfying my conditions tend to vary at times. I was wondering is it because of the thershold level i set in my programme and what other settings i need to alter to make the results more stable for experiment usage. Cheers. Thank you in advance!
Your Regards,
Scott
Message 1 of 1
(5,343 Views)
