My servo tune doesn`t work,why?
hello everyone
 My servo tune doesn`t work. the problem is :when i clicked the auto tune,the motor doesn`t move at all and the end of the process is Kp 32767 ,Kd 32767,Ki 0,Td 3,while the following error is the distance you input.what the problem?
(3,376 Views)
I would check all electrical connections, verify all wiring, and verify power first. Does motor move at all when commanded to? Encoder or other feedback device wired up properly?
(3,373 Views)
Auto tune will not work with every motion setup - often you must perform a manual tune. The following Knowledgebase walks through how to manually tune a servo (see the manual tuning section):
http://zone.ni.com/devzone/conceptd.nsf/webmain/4b7775373e4ae64986256b6000691505
(3,366 Views)
