NI 6034E for motion control?
Is it possible to use the NI 6034E multifunction PCI card for motion control on a 3 axis system?
(2,207 Views)
Accepted by confusedbme
This is an I/O board, so I don't think it is supported by Motion or Softmotion driver. That means that you won't be able to create an AXIS on LabVIEW.
Maybe you can set a +-10 PWM output and use it with a Motor driver to control 1 or several motors. To make a system in that way sounds really hard.
(2,180 Views)
