NI 73xx motion control, maximum velocity
Hello!
Last time I was testing a new step motor controller. I discovered, that when I set the velocity higher than 2000steps/s, the speed doesn't increase more than 1968steps/s. I tried to set many configurations but they didn't work properly. I must do some tests with velocity much higher than 2000steps/s... Could you tell me what do I wrong?
Simple program was created in Labview 2011
Vision and Motion drivers -> NIMotion830
NI card -> NI-7334
Universal Motion Interface - UMI-7764
Windows XP
I tried only to set velocity of stepper motor in open loop.
Thank you in advance
Mariusz
(6,324 Views)
What is the make/model or specs of your motor?
How many degrees/step, what is the maximum rpm of it also?
Are the DIP switches in the UMI-7764 set up properly for your application?
-AK2DM
(6,318 Views)
Thank you for your efforts you want to understand that issue.
But I don't understand why do you need the specification of the motor.
Anyway, in full step mode 200 steps/turn, ... ,  1/8 mode 1600 steps/turn...
I can easily reach higher velocity if I send the steps to the motor controller from external signal generator.
The problem is, UMI-7764 doesn't give properly frequency on Step(CW) pin. Even if the UMI is unconnected with motor controller, Step(CW) output doesn't reach frequency greater than 2kHz.
I carried out many tests. I set velocity to 5000 steps/s, ran program, checked frequency.
I attached print screen from osciloscope. It's below 2kHz. It should be 5kHz in that case.
I checked also if pins INHIN and INHOUT are set corretly. I don't use in that case INHIN so regarding to the specifications of UMI-7764, I left switch S2 to the bottom (active low).
(6,298 Views)
Accepted by genomar
I found solution.
The problem was too small value of acceleration/decelaration. If program realises, that the rise time of velocity will be longer than 8,196ms, it stops increasing velocity below demanded value. I have no idea why, but maybe it is caused by internal counter that handles velocity method.
After I increased value of accel/decel block, Step output easily reaches a desired frequency.
I close the topic.
(6,274 Views)
