NI-9485 Connector
We have this NI-9485 C Series Relay Output Module - (8Ch SSR 193051C-01L) and somehow lost the terminal block. I have been unable to find the part number for the 16 pin plug-in screw terminal block. Does anyone know the NI part number or the Phoenix Connector part number? Thanks.  Philip Correll at Equilibar.
(3,439 Views)
Accepted by topic author pcorrell
Is this what you're looking for? It's the NI 9975 Front Mount Terminal Blocks for 16-Position Plug Module:
https://www.ni.com/en-us/support/model.ni-9975.html
If not, you can browse here for NI C Series terminal blocks:
https://www.ni.com/en-us/shop/category/connectors.html?productId=118899
Is the Phoenix terminal block a separate terminal block?
Francine P.
Applications Engineering
(3,414 Views)
Thank you!  That was what I needed.
(3,410 Views)
