 calebyaj
			calebyaj
			12-16-2013 10:49 AM
Has this issue solved yet. Over the weekend, I had the same exact issue as described above. I have the PCI-7340 motion card. I ended up installing labview 2012 and Max 5.3 which works.
12-16-2013 01:55 PM
Hi Calebyaj,
I just checked the status for the CAR listed here and it is still being worked on. I remember seeing a very similar issue when 8.5 was released. Basically, a motion card would not appear in MAX. To my knowledge, this was fixed in 8.5.1. You can download it here:
NI-Motion 8.5.1
http://www.ni.com/download/ni-motion-8.5.1/4355/en/
 calebyaj
			calebyaj
			12-27-2013 07:08 PM
Eric-J,
8.5.1 fixed my problem. Many thanks.
 kevlar
			kevlar
			08-18-2021 05:17 PM
I'm getting this exact same error with NI-Motion 18.0, NI-MAX 18.5, and LabVIEW2018. Is there a fix for that?
Thank you.
 RIObotics
			RIObotics
			08-18-2021 08:08 PM
Hi Kevlar,
As this is a really old thread, can you clarify your situation? So you're getting the same "Unexpected Internal Warning" in MAX? Which NI board are you using? Was it in a working state before?
As NI Motion has been discontinued, we probably won't have official support from NI folks anymore. But as I've worked quite alot with it, we can see what our options are for solving your problem.
 kevlar
			kevlar
			08-19-2021 09:49 AM
RIObotics,
The error message is:
The NIMotionUI.mxx plug-in caused an exception in the CmxProviderWrapper::BindPrimary function in the Max process.
Elsewhere in the thread it said that this was being tracked by CAR 423023.
The motion controller is a PXI-7350 and it was working last week but on Monday morning I noticed that the actuator being controlled by it was not exerting any force on the test system. I opened MAX to try to move it but when I tried to expand NI Motion Devices in the System tree the error came up and MAX locked up. I ended MAX, opened it back up, and tried to Create a Report and got the same error and it locked up again without creating the report. I tried to attach the dmp file but it wouldn't let me.
Thanks again.
 RIObotics
			RIObotics
			08-19-2021 10:07 AM
Hi Kevlar,
Going to take a really wild swing at this, let's see if we get lucky:
Try this thread:
MAX database might be corrupted by anti-virus or firewall. Try resetting your MAX database.
 kevlar
			kevlar
			08-19-2021 04:07 PM
RIObotics,
Resetting the Max database did the trick. It took me awhile to remember how to correctly configure the digital outputs but the actuator is now moving again.
Thanks much for the help!
 RIObotics
			RIObotics
			08-20-2021 12:22 AM
Wow!  Guess the old trick worked after all. 😀
BTW, if ever you need replacements for 735x, I have a solution just for this purpose (sorry for the self-insert.)
P.S. Can you mark my post as solution? This way people can go straight to the answer.
