NI-Motion, 7344, NI-PAL Service Manager Problem
We have a 7344 motion card installed in a PC.  The error started to happen after we had a power failure.  When the PC starts up the following message is displayed: "NI-PAL Service Manager encountered a problem and needed to close"  The Error signature is: szAppName: nipalsm.exe, szAppVer: 2.1.0.49152, sz ModName: NIMCInit.dll, szModVer:7.2.1.3003 offset: 0001cfac.
More Details:
We have two 7344 motion cards: 1 and 2 and two computers A and B.  Both motion cards were installed in PC A when we had the power failure.  We can install card 2 into either PC A or PC B and not encounter the error.  We install card 1 into PC A and we have the problem.  When card 1 is installed into PC B the problem does not occure.
What should we do?
Pat Pointer  (patp@primatics.com)
(5,346 Views)
Pat,
this is really weird behavior. Most likely the issue is caused by a harddrive problem on PC A which might be resolved by following these steps.
  1. Run CHKDSK /F from the Windows recovery console
  2. Uninstall NI-Motion and remove the 7344 boards.
  3. Install NI-Motion 7.4 which is the latest NI-Motion version
  4. Install the 7344 boards in your PC.
I hope that helps,
Jochen Klier
National Instruments Germany
(5,339 Views)
