NI Motion card not listed in MAX
My Motion control card is not listed in MAX.
I have installed it as per the instructions - software first and hardware after that. The version of NI software I am using is 6.9.3.
I have tried going to Control Panel->System->Other Devices where the Motion Control card came up as a PCI device. I attempted to update the driver, but the OS couldn't find a driver even on the NI CD.
I atttempted to download the latest version of your Motion Control driver, but It think your FTP server must not be working.
I am running a fresh installation of WinXP SP2.
If you coulod make some suggestions on how to procees I would appreciate it.
Cheers.
(3,555 Views)
Which card are you using?
The FTP problem may not be at NI. Some firewalls block FTP sites. I had to ask our IT department to disable that.
(3,549 Views)
There is no NI-Motion 6.9.3. It looks like you have only installed NI-DAQ but this driver supports only data acquisiton devices but no motion controllers. You will need to download and install NI-Motion (latest version is 7.0). I have just tried downloading the driver and it works fine. If there is a problem with the download please contact your network administrator.
Jochen Klier
National Instruments Germany
(3,544 Views)
Thanks guys,
That's all sorted now. It was the driver. I had installed the NI-DAQ software thinking it was the NI Motion driver.
Thanks for your help. The FTP problem was here as well - our firewall was blocking it.
Cheers.
(3,529 Views)
