09-02-2010 09:14 PM
the Problem is that (channel A=PFI8) is incrementing both direction always incrementing
and channel B= PFI10 is always 0 .
About testing the the output of the Encoder I tried to test the 4 output od the encoder ( 4 wires orange, red, yellow and black) but i dont konw what is the relation between these wires and channel A, B??
Any datasheet to look at ?
Thanx alot for your help
09-02-2010 09:18 PM
If you don't know what the wires do, then how did you wire them to the DAQ card? Most encoders will have 8 wires. 2 for power(Vcc and Gnd), A, A/,B,B/, Z,Z/. To wire to a DAQ card, do not connect A/,B/, and Z/ to anything. You need to find a datasheet for the encoder or motor.
09-02-2010 09:25 PM - edited 09-02-2010 09:30 PM
The DC motor already wired by Quanser using NI ELVIS ...so i didnt do any wiring !!!
on the board there are 2 encoder reader Enc0 and Enc1 and by default the encoder is connected to Enc0
and there is only 4 wires coming out of the encoder!!
09-06-2010 12:57 AM
I used the "quadratureencoderm-series.vi" to test the encoder and i found that PFI 10 is always 0 however the encoder outputs are not.
that means that PFI 10 is not connected to the right pin !!!
Anyone knows how to change the connection of the pin I know that for M-series and the board that i'm using the PFI 10 should be connected to pin 45 and PFI 8 to pin 37 !
But how to make sure and check the connection ?
Thanx
