NI pci 6251 position control
the Problem is that (channel A=PFI8) is incrementing both direction always incrementing
and channel B= PFI10 is always 0 .
About testing the the output of the Encoder I tried to test the 4 output od the encoder ( 4 wires orange, red, yellow and black) but i dont konw what is the relation between these wires and channel A, B??
Any datasheet to look at ?
Thanx alot for your help
Message 11 of 14
(1,775 Views)
If you don't know what the wires do, then how did you wire them to the DAQ card?  Most encoders will have 8 wires.  2 for power(Vcc and Gnd), A, A/,B,B/, Z,Z/.  To wire to a DAQ card, do not connect A/,B/, and Z/ to anything.  You need to find a datasheet for the encoder or motor.
Message 12 of 14
(1,772 Views)
The DC motor already wired by Quanser using NI ELVIS ...so i didnt do any wiring !!!
on the board there are 2 encoder reader Enc0 and Enc1 and by default the encoder is connected to Enc0
and there is only 4 wires coming out of the encoder!!
Message 13 of 14
(1,769 Views)
I used the "quadratureencoderm-series.vi" to test the encoder and i found that PFI 10 is always 0 however the encoder outputs are not.
that means that  PFI 10 is not connected to the right pin !!!
Anyone knows how to change the connection of the pin  I know that for M-series and the board that i'm using the PFI 10 should be connected to pin 45 and PFI 8 to pin 37 !
But how to make sure and check the connection ?
Thanx
Message 14 of 14
(1,728 Views)
