Need guide on how to design LabVIEW layout for displaying an output from Kelly Controller to control the CompactRio
Hi guys. Do need some help here.
My task is to design a LabVIEW design shematic to display the regeneration current drawn from the BLDC motor through Kelly Controller with an output voltage range of 0-5V. The Kelly Controller is to communicate with the CompactRio. However, I do not know how to start it and I'm kinda new to LabVIEW.
Really appreciate any kind help and guide that can progress me ahead. Thanks.
(5,659 Views)
Hi kienyang90,
CompactRio guide can be found in NI website via this link http://www.ni.com/pdf/products/us/fullcriodevguide.pdf
By reading the guide, you will get an idea on how it works.
To connect compactRio with external module or sensor, you need an i/o module.
for example an analog input module is this one https://www.ni.com/en-us/shop/model/ni-9201.html
You have to pick modules depend on what kind of output source you are going to give to the compactRio
Hope this help
TuiTui
(5,644 Views)
