Need to connect a PCI-7332 cable to a panel and then to an UMI-7764
Message 1 of 8
(5,756 Views)
hey Carlos,
Here is a good starting point.
A. Zaatari
Message 2 of 8
(5,746 Views)
Dear A. Zaatari,
I don´t understand why the details of my post didn´t show up. Sorry.
In fact, I need to connect the PCI with the UMI, but the UMI is inside a case. So, I need to connect the PCI to a panel connector and then this connector to the UMI. I have doubts about this intermediate connection. How to do this? Which connector should I use?
On the other hand, I could use a cable to connect directly to another cable (from the UMI to the panel) attached to the panel.
I really appreciate if you could help me.
Best regards.
Carlos.
Message 3 of 8
(5,736 Views)
Hey Carlos,
I am still not sure what this intermediate connection is? Can you post pictures or part#? Is it something we sell, or was it custom made?
A. Zaatari
Message 4 of 8
(5,732 Views)
Hey Zaatari,
I am developing my product yet. As I told you before, I need a connection from the PCI to a panel of my product. And them, from the panel to the UMI. How to do this? I´d like to know which connector I should use. NI sell these parts?
Unfortunately, I can´t do a direct link using a single cable from the PCI to UMI.
Regards.
Carlos.
Message 5 of 8
(5,728 Views)
Carlos-
Why can't you go direct?  Is it because of length, or just getting throught the cabinet?  If it is length, I believe there is a spec for that, and it is pretty short.  If it is getting through the cabinet, then I have used Roxtec sealing devices before.  Depending on which Roxtec you use, you might have to take the shell off the connector to get it through, then put the shell back on.
Brian
Message 6 of 8
(5,722 Views)
Dear Brian, thanks for your message!
The problem is getting thought the cabinet. Could you send me more details about the solution with Roxtec you mention it?
Regards.
Carlos.
Message 7 of 8
(5,716 Views)
Take a look here: http://www.roxtec.com/
Message 8 of 8
(5,714 Views)
