Motion Control and Motor Drives
Ni-Motion Rookie..."Vector Space" velocity profile
I am a novice LabView user responsible for programming a 2 spindle winding machine.  The spindles are to move in linearly increasing (and correspondently decreasing) speeds.  I have accessed the NI-Motion Assistant and have been told that programming a very low acceleration with regards to the actual rpm of the motor has the same effect as programming an increasing speed profile.  This being said, if i had to input a variable that would allow access into whatever databank of numbers the program has set aside for the changing speeds (due to different input diameters of a rotating spindle of unwinding/winding material), where is this task performed?  I have searched the canned, example, and NI-Motion Assistant vi's and still cannot see where this interaction with the vi would take place.  Help is greatly appreciated.
Chris (uconnsenior)
Message 1 of 1
(3,584 Views)
