Motion Control and Motor Drives
PCI-7344 motion controller encoder reset problem
I'm using a PCI-7344 motion controller for my application. I'm currently working on simple display of position and velocity using an encoder. I am able to read the encoder pulser, but I am unable to reset it. I want the encoder pulses to be display continously till I press a reset button on the screen. After pressing the reset button on the front panel, the encoder count should become zero and start counting again till I press stop button. Kindly give me a simple example of encoder reset using push button. Thanks.
Giridhar Rajan
Cruiser Controls
Mumbai, India
(3,377 Views)
This should do what you are looking for.  I am not at the computer that has a motion controller card in it, so I have not tested it.
It resets the encoders for Axis 1 and Axis 2.  Unless you have a different configuration for encoders and axes, it should work.
Hope that this helps,
Bob
(3,372 Views)
Hi Bob,
Thanks for the VI. We'll keep in touch.
Bye.
Giridhar Rajan
Cruiser Controls
Mumbai, India
(3,366 Views)
