PCI-7352 Corrupt Firmware
I have a system with a PCI-7352 motion card that was running under LabView 7.0. I just upgraded to LabView 8.6 and when I go to MAX and do an initalize I get this:
-70056 (NIMC_corruptFPGAFirmwareError)
The upgrade firmware button is grayed out. Any suggestions?
Jason
Message Edited by JTMX39 on 04-01-2009 08:33 AM
(4,562 Views)
The FPGA1 version is 7.10.3001. Currently the servo is not connected to the card.
(4,558 Views)
Please upgrade to the latest NI-Motion driver which is currentlyversion 7.6. If this doesn't help to resolve the issue, your board probably needs a repair. Please contact your local NI branch to assist you with the repair process
Jochen
(4,554 Views)
Thanks Jochen, but I just installed v.7.7 and I get the same thing.
(4,552 Views)
Ok, in this case the firmware on the board is obviously corrupt and the board needs a repair.
(4,537 Views)
Accepted by JTMX39
After talking to NI Tech Support there is an option in MAX to download just the FPGA file. It downloaded successfully and now it works !! I think something had happened during the original firmware upgrade.
(4,532 Views)
