PCI-7390 Onboard program error-70022
I am using a PCI-7390 Motion card. When I run the example vi  “Onboard Program.vi” an error happened. It shows that
“   Error-70022 happened in Begin Program Storage.flx
      Possible reason
      Motion:This command is not supported by this controller or orperating system.”
Dosen't the PCI-7390 controller support Onboard Program ?
May there something worry with the setting?
 Thanks!
(4,114 Views)
Accepted by topic author 小飞侠
This example is not supported on NI 7330 or NI PCI-7390 controllers." but7340 and7350 support On-board program。
(4,099 Views)
