05-09-2006 06:42 PM
05-10-2006 03:54 PM
05-10-2006 05:05 PM
I am using four amplifiers; three are on linear motors, one on a ball screw.
Two of the four linear motors drive the parallel tracks in an H-Bridge (X and X')
The third linear motor drives the crossbar.
The crossbar motor continually "drops out"; i.e. it gets following errors and will not restart.
The parallel motors seem to build up tension even though they report being at the same position.
The ball-screw works fine.
05-11-2006
04:39 PM
- last edited on
11-17-2025
10:21 AM
by
Content Cleaner
Is this motor/drive a servo or stepper?
If it is a stepper, make sure that your Stepper steps per revolution and Encoder steps per revolution are set correctly in the Measurement & Automation Explorer.
If it is a servo, the motor may not be properly tuned. Follow the steps in the tutorial below to manually tune your motor:
Understanding Servo Tune
See the KnowledgeBase article below to help troubleshoot the following errors:
KB 3QGEF7D3: Following Error in a Motion Control System
What exactly is happenning when you say "The parallel motors seem to build up tension even though they report being at the same position"?
Allen H.
05-12-2006 07:26 AM
05-15-2006 07:41 PM
