Problem with pci-7344
In my application I need to detect a random-positioned markon a rotary table. For this I use a sensor wired to the high-speed capture input.
I have noticed that when I use the following sequence of wait functions:
flex_wait_on_condition (1, 0, NIMC_WAIT_OR, NIMC_CONDITION_MOVE_COMPLETE, 0x04, 0x00, NIMC_MATCH_ANY, 160, 5);
flex_wait_on_condition (1, 0, NIMC_WAIT, NIMC_CONDITION_HIGH_SPEED_CAPTURE, 0x04, 0x00, NIMC_MATCH_ANY, 160, 5);
the on-board program detects the mark much better than if I use the functions in reversed order:
5);
I other words, the detection works much more reliable with the first sequence than with the second, when most of the times it is completing the move w/o detecting the mark.
Why is this happening?
(3,668 Views)
Hello Florin,
For onboard programs, there is a race condition (internally on the board) that occurs when the NIMC_WAIT_OR is used.
- The issue should be resolved in the next revision of the FlexMotion driver.
- www.ni.com/download
As a workaround for your current program, you can call the NIMC_CONDITION_HIGH_SPEED_CAPTURE with a NIMC_WAIT, and you will detect the high speed capture.
- In a seperate program, you can monitor the Move Complete status, and stop the onboard program if when it occurs.
Please let me know if you have any questions,
Alan Hagler
(3,668 Views)
