08-23-2012 09:39 AM
I would like to know if in order to programmatically limit torque for a servo axis to be between -7V and +7V (rather than the default +/- 10V) I would have to call the "Load Torque Limit.flx" vi before every single move. If that is the case, is there a way to set the torque for an entire program run-time (other than manually setting it in MAX before running the program)?
Vlad
08-24-2012 03:29 PM
Hi Vlad,
I believe you will have to call the VI each time and the only place I am aware of changing the limits wound be in MAX under Axis #>Control Loop Setting> Torque Settings Tab.
Limiting the DAC Output Voltage on a Servo Axis
http://digital.ni.com/public.nsf/allkb/CE34F1F1BAE5456C8625720B0080AD34?OpenDocument
Tim O
