Motion Control and Motor Drives
Reserved pins in NI9514
Hi guys,
I found that there're many reserved pins in module NI9514. Is there any way that reserved pins can be programmatically changed to a analog output or anything like that? Many thanks in advance!
Best Regards
(2,418 Views)
Accepted by ZeSuli
Hi ZeSuli,
no, you can not access the reserved Pins.
You have no access to the internal chips that are connected to these Pins.
Best wishes
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(2,399 Views)
