Soft motion error.
When deploying any motion command to a CRio using softmotion.
It fails to deploy NIMC.create.vi  Any one else seeing that. We are using labview 2012 and NI 9512 modules.
We are trying to just follow the tutorial and it fails to deploy.
Thank you in advance.
(5,501 Views)
Hello Jeff,
A fairly open-ended problem, but let's see if we can pin down some details.
Which cRIO are you using?
Could you capture and post more information from the error log itself?  It seems odd to me that it would fail to deploy on a particular VI, assuming everything actually fits on the target, so I'm curious to see the rest of that log.
Edwin!
(5,489 Views)
