 wbadry
			wbadry
			11-09-2012 04:24 PM
I noticed that the examples shipped with NI Softmotion module is not updated. Although the directory has been changed, the example still points to LabVIEW 2009 folder. I also would like to ask whether these examples was tested with LabVIEW 2012 as it doesn't run with my machine which has LabVIEW 2012 and Solidworks 2010 SP4.
Your help is much appreciated.
11-12-2012 05:45 PM
Hi VBCoder,
Thank you for the feedback. I am trying to get the examples you mentioned, I believe that I will have to have SolidWorks installed first to see them so that may take some finagling, but in the mean time, I have a couple of questions. Note: I did see your other post with the error message we are getting.
First, I was wondering if you are using the NI LabVIEW-SolidWorks Mechatronics Toolkit Alpha version (see here)?
Second, I wanted to confirm that the examples work in 2009 (or which non-2012 versions if any).
