SoftMotion 2012 Example update
I noticed that the examples shipped with NI Softmotion module is not updated. Although the directory has been changed, the example still points to LabVIEW 2009 folder. I also would like to ask whether these examples was tested with LabVIEW 2012 as it doesn't run with my machine which has LabVIEW 2012 and Solidworks 2010 SP4.
Your help is much appreciated.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(5,562 Views)
Hi VBCoder,
Thank you for the feedback. I am trying to get the examples you mentioned, I believe that I will have to have SolidWorks installed first to see them so that may take some finagling, but in the mean time, I have a couple of questions. Note: I did see your other post with the error message we are getting.
First, I was wondering if you are using the NI LabVIEW-SolidWorks Mechatronics Toolkit Alpha version (see here)?
Second, I wanted to confirm that the examples work in 2009 (or which non-2012 versions if any).
Bill E. | Applications Engineer | National Instruments
(5,526 Views)
