Motion Control and Motor Drives
Spline Reset Position
I can't find any documentation on what the Reset Position input of the Spline Engine does.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(5,887 Views)
Hi Steve,
There's a more in depth description in the Spline Engine detailed help. The previous link will take you to the online version.  Look under the Block Diagram Inputs section.  In short, it appears to temporarily stop movement, and output a valid Setpoint value of 0 to make the current position the new zero point.
Hope that helps,
(5,875 Views)
Thanks Eric, I'll look at this
steve
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(5,866 Views)
