This widget could not be displayed.
Spline Reset Position
I can't find any documentation on what the Reset Position input of the Spline Engine does.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(5,881 Views)
Hi Steve,
There's a more in depth description in the Spline Engine detailed help. The previous link will take you to the online version.  Look under the Block Diagram Inputs section.  In short, it appears to temporarily stop movement, and output a valid Setpoint value of 0 to make the current position the new zero point.
Hope that helps,
(5,869 Views)
Thanks Eric, I'll look at this
steve
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(5,860 Views)
