Stand Alone Executable using NI-Motion
I am developing an application using LV 7.0 and NI Motion. The application will be installed on a different machine with no Labview on it. Other than Labview run time engine what else would I need for this application to run on this other machine (with no Labview no MAX on it). Please give me the NI part numbers. Thanks
(3,651 Views)
To be able to use your motion board you will have to install NI Motion on your target machine. MAX will be installed as part of NI Motion.
Jochen Klier
National Instruments Germany
(3,648 Views)
Thanks. And what about Application. Do I need to buy a deployement engine with it. Or some kind of License so that NI motion works fine on the other machine.
(3,645 Views)
No. That's all. Just install the NI-Motion driver and the LabVIEW Run-Time Engine or create an installer for your application as this will install both, the application and the Run-time Engine on your target system.
In LabVIEW 8.x it's also possible to include the NI-Motion installer and the hardware configuration within the application's installer. Thus you end up with a single installer that results in a ready to run system.
Jochen
(3,638 Views)
