No. That's all. Just install the NI-Motion driver and the LabVIEW Run-Time Engine or create an installer for your application as this will install both, the application and the Run-time Engine on your target system.
In LabVIEW 8.x it's also possible to include the NI-Motion installer and the hardware configuration within the application's installer. Thus you end up with a single installer that results in a ready to run system.
Jochen
