10-14-2007 06:25 AM
Hi guys,
I would like to purchase a standalone motion controller for 6 existing stepper motors and their drivers. By standalone I mean that it will be controlled via Usb or TCP/IP and located outside of the PC.
Also, I would like to be able to build a Labview application for it, so Labview drivers and support are important.
As a reference, the Parker ACR9000 meets most of our demands, only it does not have Labview drivers coming with it.
The Datasheet for the ACR9000 is given here: http://www.parkermotion.com/literature/pdf/ACR9000_brochure307.pdf
Could anyone please suggest a suitable hardware ?
Thanks.
Michael.
10-14-2007 07:42 PM
10-15-2007 11:34 AM
National Instruments offers an Ethernet Motion Control system using the NI PXI System and LabVIEW Real-Time. The system comes with a 4-slot PXI chassis so you can customize which motion controllers you would like to have installed. If you would like to have 6 axes in one controller, I would recommend the PXI-7356 stepper/servo controller. An 8-axis controller is also available so combined with the 4-slot chassis, you'd have the option to go all the way to 24 axes of control all running on a Real-Time system, so it gives you a lot of room for expansion. If you are running a simple motion control program for the 6 steppers, then it will be a bit more than you'd need, but I wanted you to be aware of the variety of hardware setups available to you.
05-16-2008 07:33 AM
Mic_Scale,
Did you (or anyone else) end up controlling the ACR9000 through LabVIEW? I have just started on a program with an unfortunately aggressive deadline; I have the ActiveX and .NET files provided by Parker but would like to know if you've had a positive experience incorporating these into LabVIEW...or if there are stumbling blocks to look out for.
Alex
05-19-2008 02:05 AM
05-19-2008 07:12 AM
Thanks, Mic_Scale!
I figured as much with all the info I downloaded from Parker's site - but it did not include the pdf document you sent. The Parker people I talked to, all of whom were really helpful, seem to only know of one other person using the ACR9000 with LabView. I've got some stuff up and running within VIs - if/when you pick this project back up let me know and these might save you some time. It's a work in progress right now.
Alex
05-19-2008 09:28 AM
05-20-2008 10:36 AM
Michael,
See the attached zip folder for an example of how to write command-line instructions to the ACR9000 via LabVIEW. I think this is what you are referring to. I learned an important lesson yesterday - have the Parker people send you the most up-to-date manuals and help files, because the ones online are a bit old and do have some errors in them.
See the VI Properties-Documentation part of the attached VI for information on what the default command does. The key for me was learning that I have to assign a "Master" through the ActiveX terminal (i.e., "prog 0", "prog 1") - otherwise the commands you send seem to do nothing at all.
Alex
05-21-2008 12:48 AM
Hi Alex,
Can you please save this file as a 8.0 Version and reupload please ?
I have Labview 8.2, and it won't let me load your 8.5 version.
Thanx.
05-21-2008 06:18 AM
Here you go -
Alex
