09-21-2007 07:33 AM
Hello everyone,
I have a problem about the step response function of the MAX. First let me give some details about the motion controller system I’m using.
I need to create a system to control Maxon motor position. I’m using PCI-7358 as controller and MID-7654 as servo driver. I tuned my servo axis using MAX and always checked the step response subroutine under the Servo Tune tab. The servo tune was good I think with the PID values I used because the analysis table showed that the settling time is 6ms and the rising time is 0ms and I have no overshoot.
Then I used the jog axis subroutine under the same Servo Tune tab and this time the response of the actuator system becomes ~30ms. (The step response and the jog axis commands are given for 1024 counts.)
What is the difference between the jog axis and the step response of the MAX? How do these two subroutines graph the motion defined?
09-21-2007 08:29 AM - edited 09-21-2007 08:29 AM
Message Edited by Jochen on 09-21-2007 03:30 PM
09-22-2007 03:31 AM
09-24-2007 04:37 AM
09-27-2007 01:20 AM
Hello Jochen Klier,
I was working on our system. I have a very short question and am looking forward your reply.
You said that that the graph in step response is drawn calling standard flex_read_position but also in another thread you said that the register that holds the read position value is updated in 5ms. But as I said the step response graph is much smoother than that update rate.
Thank you for your kind interest.
Gencer Genc
Roketsan Co.
09-27-2007 02:55 AM
09-27-2007 02:05 PM
