connecter
Can connect SCXI-1161 to PXI chassis with use adapter?
if the answer is true please give me the modle adapter and price
if the answer is no please give me the method connect SCXI-1161 to PXI chassis
Regard
bedaiwi
(3,315 Views)
Hello bedaiwim,
Thank you for contacting National Instruments. The method to connect the SCXI-1161 to the PXI chassis depends on how you are trying to control it.  If you are trying to use a DMM (such as the PXI 4060) or the PXI 4021, then you would need the SCXI 1362 kit. If you are trying to use one of our E series or M series DAQ modules, then you would need a SCXI 1349 with a SH68-68-EP cable.  I hope this is what you are looking for, don't hesitate to ask if you have any more questions.
Neal M.
NIC AE
www.ni.com/support
Neal M.
Applications Engineering       National Instruments        www.ni.com/support
(3,303 Views)
