TTl output PCI-7342 & SCB 68
In my application, I have to control a servomotor. For that, I have the PCI 7342 with the UMI 7764 interface... Also,I would like to use the 32 DIO of the PCI 7342 for send and receive data...( I use the SCB68)
In the SCB 68, I have connected on the port 1 bit 0 an electronic chart to control brakes...But I have to send on this port a +5V signal....
My problem is that I don't know sufficiently Labview to know which is the VI adapted that would allow me to realize this...
I am completely blocked. I would like that you help me.
THANK YOU .
Cordially
Murat
(3,407 Views)
Murat-
You should be able to use the "Set I/O Port MOMO" VI which is under "Analog and Digital I/O" in the Flexmotion palette.
(3,404 Views)
