01-19-2011 01:20 PM
I am using a UMI-7772 and a PCI-7330 board to control a stepper motor(KL34H260-60-4A) with a CW230 Microstep motor driver. Could you please tell me how to connect the wires and how to setup in Labview to control the motion of the motor? Thanks.
01-20-2011
12:06 PM
- last edited on
10-02-2025
08:32 AM
by
Content Cleaner
Hi jingrui,
As far as the physical wiring of the UMI 7772 to the CW230 Microstep Motor Drive, go ahead and take a look at the manual I linked below. This will provide the pinout information for the PCI-7330 which corresponds to the pins of the UMI-7772. Then all you need to do is consult the manual for the CW230 and match pins from the UMI-7772 to the corresponding input on the CW230.
https://www.ni.com/docs/en-US/bundle/370837b/resource/370837b.pdf
As far as the software configuration of the motor, check out the two tutorials that I've linked below. They provide a good starting point on what configuration settings you need to adjust in Measurement & Automation Explorer as well as how to begin programming in LabVIEW. Let me know if you have any other questions.
http://zone.ni.com/devzone/cda/tut/p/id/3126
http://zone.ni.com/devzone/cda/tut/p/id/3367
Paul M
