The configuration steps for stepper motoer with UMI7772
I am using a UMI-7772 and a PCI-7330 board to control a stepper motor(KL34H260-60-4A) with a CW230 Microstep motor driver. Could you please tell me how to connect the wires and how to setup in Labview to control the motion of the motor? Thanks.
(4,507 Views)
Hi jingrui,
As far as the physical wiring of the UMI 7772 to the CW230 Microstep Motor Drive, go ahead and take a look at the manual I linked below. This will provide the pinout information for the PCI-7330 which corresponds to the pins of the UMI-7772. Then all you need to do is consult the manual for the CW230 and match pins from the UMI-7772 to the corresponding input on the CW230.
https://www.ni.com/docs/en-US/bundle/370837b/resource/370837b.pdf
As far as the software configuration of the motor, check out the two tutorials that I've linked below. They provide a good starting point on what configuration settings you need to adjust in Measurement & Automation Explorer as well as how to begin programming in LabVIEW. Let me know if you have any other questions.
http://zone.ni.com/devzone/cda/tut/p/id/3126
http://zone.ni.com/devzone/cda/tut/p/id/3367
Paul M
National Instruments | Applications Engineer | www.ni.com/support
(4,493 Views)
