The version of the LabVIEW NI SoftMotion Module installed on the host differs from the version installed on the RT target.
i got this problem when i want to deploy the project with softmotion
https://www.dropbox.com/s/at9r9w667i00qja/qqqqqq.png
NI SoftMotion:  The version of the LabVIEW NI SoftMotion Module installed on the host differs from the version installed on the RT target.
Message 1 of 19
(7,049 Views)
Hi Eng.Tareq
It would be better if you can give more information
1. What is the software version are you using?
2. What is your target hardware?
You can check the above information by open MAX -> under software tab of both computer and you target
I suspect that the software version of your host computer and the target is difference as state in the picture attached.
TuiTui
Message 2 of 19
(7,033 Views)
i donno how to check these things ?
can i have any guide ?
Message 3 of 19
(7,030 Views)
Hi Eng.Tareq,
To check the software version, You need to open MAX and go under software drop down list.
TuiTui
Message 4 of 19
(7,003 Views)
how can i check this
the software is 2010
Message 5 of 19
(6,999 Views)
Hi Eng.Tareq
In MAX, under your target there should be a software drop down for you as well
TuiTui
Message 6 of 19
(6,983 Views)
Hi Eng.Tareq,
Can you tell me what is your RT target? as i don't see any hardware that you are using.
TuiTui
Message 8 of 19
(6,959 Views)
how can i know the RT target ?
Message 9 of 19
(6,954 Views)
Hi Eng.Tareq,
You have said that you deployed you program. What is the hardware you deploy to?
TuiTui
Message 10 of 19
(6,949 Views)
