error 89139
I have a PCI-6723 and PCIe-6536 and use LabView 2012. I would like to give a time sequence for this two boards and output them. I connect this two boards with a RTSI line to get the synchronization. However, I get an error-89139(There are no shared trigger lines between the two devices which are acceptable to both devices. While each of these two devices support some shared trigger lines, none of these shared trigger lines work for both devices for the specified property and corresponding value.)
VI attached. It has four VIs so I compress them. "Cs BEC" is the main VI.
Chenny.li
Message 1 of 1
(5,566 Views)
