UMI-7764
What is required to make the Inhibit Output  siganl work.  I can not get the signal to change.  I have tried the S1 switch in both postions with no control of the inhibit output.  Any ideas?
(3,661 Views)
The Inhibit signal is a sinking output.  Hence it has two states: ground and floating.  When connected to a sourcing input, proper behavior is seen.  When the signal should be +5V, the input supplies +5V and the output is floating, so the signal is at +5V.  Similarly, when the signal should be 0V, the output is ground and the input is floating, which makes the signal 0V.  If you are connecting a multimeter to the Inhibit of the UMI, you will need to add a pullup resistor to see a 0-5V swing.  For more information, I recommend looking at this link.
Ryan M
(3,645 Views)
