measure displacement in "mm"
Dear:
I need to development a system to mesure a displacement of a axis in mm. Let me expain: I'm control a servo system Festo with a PXI-7350 + UMI-7772. Through the analog output, we control the velocity of the motor. The UMI receive the signal of the encoder and through of him, I think to do the measure. Do you have some idea how to do this?
Thank you.
Clécio.
(3,571 Views)
If you poll the encoder reading before and after the move and know how much 1 count is in displacement then just do the math. This assumes no slippage or slop in the motion mechanics. Distance = (# counts moved) * (displacement/count)
(3,566 Views)
Are you using a ball screw arrangement to move slides. In that case,
Displacement in mm = (counts read / pitch) * encoder counts per revolution
Remember that we set encoder counts in quadrature.
Giridhar Rajan
Automation Engineer
Cruiser Controls
Mumbai, India
(3,549 Views)
Sorry the above formula is a bit wrong, the correct one is below,
displacement in mm = (pitch / encoder counts per revolution) * counts read
Giridhar Rajan
Automation Engineer
Cruiser Controls
Mumbai, India
(3,548 Views)
