USS protocol library
Hi Flo, i'm working with a micromaster 440 for my thesis.
Now i have to make it work with labview, i've tried several things but i don't get a connection.
Maybe also a part of the problem is i use a serial to USB convertor.
But in the measurement and automation explorer from labview it finds it under com 6.
do u have something like a vi i can use ?
And maybe some explaining with it ?
Thank u.
Dennis
Message 21 of 64
(6,363 Views)
Dear Dennis1,
Can you specify what type of serial converter are you using? I mean what type of serial communication?
Marton
NI Hungary
Message 22 of 64
(6,348 Views)
It's with the normal RS232 cable, but i hafe a serial to USB converter in my PC, because we don't have a serial port on this pc (it's crazy but it's Greek 🙂 )
Message 23 of 64
(6,343 Views)
The usage of general USB - serial converters are usually transparent for the user, I guess our problem is not that 🙂 Are you able to communicate with the device using the original software?
Marton
Message 24 of 64
(6,316 Views)
yes I was able to communicate with it using the original software,
but it seems very unstable, slow responding, and disconnecting all the time.
but now we moved on with another idea, just use analog outputs from labview to controll it.
It`s much more stable and faster.
Message 25 of 64
(6,310 Views)
New version of the library
version 1.1 - 20.07.2009
-Resending algorithm implemented into each command. Added RepCount terminal setting the number of attempts to perform to send the telegram
-Minor changes
LV 2011, Win7
Message 26 of 64
(5,909 Views)
Version 1.2 - 12.11.2009
-Read commands resending implemented
-Minor changes
LV 2011, Win7
Message 27 of 64
(5,384 Views)
hi folks,
sorry for the delay. here are the significant parameters for MM440
r0000    0
P0003    1
P0004    0
P0010    0
P0310    50.00
P0311    2815
P0700    2
P0970    0
P1000    1
P1080    0
P1082    50
P1120    5
P1121    5
P3900    0
i can add code by tomorrow, but i  would first have to comment it.
cheers
flo
Message 28 of 64
(4,985 Views)
mm440 users,
here is the code. it is based on some previous version of ceties` framework with a few modifications. please check whether it does the trick for you.
good luck
flo
Message 29 of 64
(4,981 Views)
how conection you use RS232 or RS485?
Message 30 of 64
(4,917 Views)
