USS protocol library
It shouldn't matter. You just have to set the inverter accordingly
LV 2011, Win7
Message 31 of 64
(5,055 Views)
hi flo!!!
help please!!!
how I can change P2012 and P2013 in mm440 or you uss library??? becouse I have error 5008(incorrect byte count) if baud rate 9600 or error 5007(missing STX) if baud rate 38400
Message 32 of 64
(4,994 Views)
Is there a way to have these libraries in 8.5 LabView version please?
I am developing a project with some 420 and 440 drives, and it would be great to use this library.
Gilberto Garza
Gilberto Garza Gzz.
Certified LabView Developer
Asesor Electrico, S.A. de C.V.
Message 33 of 64
(4,785 Views)
Dear Gilberto,
I have conerted the files Flo has posted to LabVIEW 8.5 format, I hope it will work for you. If it doesn't or if you have any other questions, please don't hesitate to ask.
Have a wonderful day!
Zenon Kuder
Applications Engineering
Message 34 of 64
(4,778 Views)
Thank you very much Zenon, it will help me a lot!
Gilberto Garza
Gilberto Garza Gzz.
Message 35 of 64
(4,768 Views)
Do you have the files available for LabVIEW 8.2?
Message 36 of 64
(4,524 Views)
Dear Parga,
I converted the files for LabVIEW 8.2, nevertheless there were some changes in several of the used VIs, so I'm not sure if it will work for you. Can you please check and let me know if it did work or not?
Thanks you!
Zenon Kuder
Message 37 of 64
(4,510 Views)
Dear Zenon,
Let me play with the files and my inverter for a couple of days and then I will let you know if I have troubles with them.
Thank you very much for your promptly support.
Abraham Parga
Message 38 of 64
(4,500 Views)
Thank you very much, I am working with the MM420 now and the PZD is max of 4 words, do I have to modify the vi PZD_USS.vi to make it work?
Gilberto Garza
Gilberto Garza Gzz.
Message 39 of 64
(4,065 Views)
The original library expects PZD=8. So you will have to dive into the code to alter it. Not sure about the altered llb intended for MM440 but if it now reads also 8 words, it will be same case.
LV 2011, Win7
Message 40 of 64
(4,057 Views)
