Updating numeric Control with different values with array function
Hi ,
I have attached my basic code . I want to run the code for 2 sets of numeric control values with a delay in between and loop it. Something like this
abc
Initialize P1=10; P2=20;P3=30;P4=40
Run the code
delay = 10ms
Update P1=150; P2=200;P3=350;P4=500
Run the code
jump to abc
I am stuck how to update the values of P1,P2,P3,P4 ? I thought of using a array function but couldn't go further .
Thanks for the help,
Ana
Message 1 of 8
(7,350 Views)
Accepted by topic author Sshenoy
Hello Ana,
One way you could achieve what you are looking for is by using property nodes. These Property nodes will allow you to change control values from the block diagram. You could set up a case structure inside of your while loop that will change the control value via property nodes after a certain number of iterations. Here is a community example that shows how to use property nodes to change boolean controls:
https://decibel.ni.com/content/docs/DOC-22669
-Erik S
Message 2 of 8
(7,333 Views)
Hi Erik,
Thanks for your reply. I am trying to use the property node -> value. I am still not sure how to write values to it. Would you be having some simple example for me ?
Sahana
Message 3 of 8
(7,324 Views)
Please correct me. I am still stuck.
Message 4 of 8
(7,310 Views)
Got it working 🙂
Message 5 of 8
(7,294 Views)
I am not sure what is the best method to update numeric control P1, P2 , P3, P4 multiple times? I have used property nodes when I had only few values to send. How can I send 4*50 array.
I am using Dynamixel MX 64 servos in my project. I have 4 of them tied in series. P1,P2,P3, P4 represents degree rotation of each servo/axis. Trying to pass multiple set of values to these variables.
Really appreciate your help!
Sahana
Message 6 of 8
(7,100 Views)
Hi Sahana,
Instead of using Property Nodes here, you may want to simply index the array of values with a for loop. Here is a Community Example that explains this functionality a bit further:
https://decibel.ni.com/content/docs/DOC-20828
-Erik S
Message 7 of 8
(7,066 Views)
Thanks Erik !
Message 8 of 8
(7,030 Views)
