simultaneous motor control
Hi everyone,
I am building a robot with tank treads that has two motors: one for the left side and one for the right.  I am using an arduino, xbee communication, and this motor driver. I would like for both motors to turn on at the exact same time, but there is a slight delay in one of them, causing the robot to not drive straight.  I am not sure if this issue is due to labview, the xbee, the motor driver, or arduino.  I have attached a copy of my vi.  Do you guys have any idea as to why this is happening?
mvilla
(5,870 Views)
The Arduino VI's are not re-entrant, so only one can be communicating at a time.  You have them wired for "parallel" operation, but that will never happen.  Each one will run in an undetermined order.  Here is a quick example of how I would do it.  Write to the port instead of the pin.  I am not sure if I have the index numbers correct for the Replace Array Subsets.  Not sure if the Arduino pins are zero or one based.
(5,866 Views)
Thank you, would you mind converting it so I can view on LabVIEW 2009?
(5,853 Views)
I can't go back that far.  Here is a screen capture.
(5,851 Views)
